Allows you to edit the specified profile.
profile-name | Specifies the UPM profile to be edited. |
N/A.
Use the command to have VI-like editor features for editing the profile. Changes appear when you close the file for editing, not when you save it.
This command was first available in ExtremeXOS 11.6.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the Universal Port feature, see the Switch Engine v33.1.1 Licensing Guide document.
